We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
The title says it all. I want to select a large set of APs, then bounce them.
(I know I'm not the first to suggest this, but I want to get more attention on the feature.)
I fail to understand the use case for this, this won't ever get any traction without a proper business case.
There is an API for reboots and I'd look into it. We developed a tool internally that allows to schedule reboots for all of our clients.https://developer.cisco.com/meraki/api-v1/reboot-device/Depending how often its needed, you could just run it in Postman as a runner without needing to develop anything.
Thanks, I'll look into it. I just wish I could do it without an API. (The API is super easy, but not all sites I've worked at have the API enabled.)
My advice is to use the GIVE YOUR FEEDBACK button the Dashboard (bottom right) and provide this feedback.
