Event log from a specific SSID
Aimad
Hi
I want to check log from a specific SSID (for exemple guest_ssid).
How I can do that ? Because in "network wide - event log" we can not filter by ssid.
Only by AP or event type or clients.
kYutobi
Well you can check the clients to see what was going on when they were associated to the SSID. You can also use the "Wireless Health" tab to check connections for SSID's there.
Enthusiast
kYutobi
Enthusiast
Aimad
Ok 🙂
Thanks for you explanation.
Froggy
Just noting it's now 8 years later and Meraki still has zero solution to sparse logs via the SSID. Impressively awful.
