- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Failed connection to SSID (x) on AP (x) during association - error_code='55'
Good day everyone
I have some users on my Wireless LAN that are failing to connect to an SSID. This SSID is open with only Radius authentication.
The building is quite a dense Wireless network with a lot of AP's. 802.11r is enabled on the AP's as well.
The error code when looking from the Network Wide > Clients > Roaming point of view is: Failed connection to SSID (x) on AP (x) during association
When looking at the Meraki logs, the error code is as follows: auth_mode='wpa2-802.1x' 11k='1' 11v='1' ft='1' reassoc='1' error_code='55' radio='1' vap='0' channel='100' rssi='51'
Does anybody know what the cause of this error code might be? I have looked through all documentation and I can't find anything on error code 55.
Thanks in advance
Etienne
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Is that access point setup on the radius server end as a NAS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Blake. The AP's are all added to an ISE with all Users' credentials.
This issue is intermittent. There will be a lot of successful connections to an AP and then sometimes a user would fail to connect.
This happens at random with random users in the network and random AP's. I have not been able to replicate the issue with a specific user or a specific AP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you verified that all your AP’s are in the right subnet?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have confirmed that all AP's are in the same subnet. All of their IP's are static and are added to ISE for authentication
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Try disabling the 802.11r.
While many customers enable 802.11r within their network without issue, some legacy devices may not connect to an 802.11r network. 802.11r is a recommended feature due to its many benefits, however a device audit is encouraged first to ensure that mission critical devices are not affected.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This would be my advice too… or turn on ’adaptive’ - although I’ve seen this cause issues too but at least your Apple devices would still benefit.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Anything showing up from that page ? :
Is the device able to connect or it fails at random times ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are these Windows 10/11 devices that are connecting, then losing connection when roaming to a new access point?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That + Intel NIC + MR29.XX firmware that would be my guess
