FIREWALL LAYER 7 MR-44
Yazmin2
The Access Point MR-44 can block users by the type of Operating system such as Android, Windows, Mac?
Yes,
https://documentation.meraki.com/General_Administration/Licensing/Systems_Manager_Licensing
You can apply policies by device type, but some clients may misidentify themselves when specifying the User-Agent string field of an HTTP GET request. Device type policy enforcement is done on a best-effort basis, dependent upon the information that the client provides. When needing to enforce security-focused policies based on device type, please leverage solutions such as Meraki Systems Manager, or Cisco ISE.
https://documentation.meraki.com/MR/Group_Policies_and_Block_Lists/Applying_Policies_by_Device_Type
Para tener Meraki Systems Manager necesito algun licenciamiento adicional?
Yes,
TBHPTL
Yes it will on a per SSID basis up to 11 device types , many options  block and custom policies. its a basic control but as other have said there are other ways to do this, but if you have a use case it will work with some caveats.
