Ethernet to Wifi adapter
Karl_Jacobsen
Okay folks, here an interesting one.... I have a public wireless network in my Meraki environment that is in NAT mode using Meraki DHCP. I have a few business class multifunction copiers I'd like to use on this network as a printer. I've seen Ethernet to wireless adapters from companies like Netgear and IO but they rely on WPS which isn't supported under Meraki. Has anyone done something like this? I know it's a little unorthodox but this is for use maybe a handful of times a year.
NolanHerring
As far as model, a 3b or better will work just fine.
This was all the information I could find regarding how it was done (a while ago):
Setting up a Raspberry Pi as a Wi-Fi <---> to <---> Ethernet Bridge:
  • Configure wireless settings to connect to your SSID
    • Edit the wpa_supplicant.conf
Sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Country=US
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="<your_SSID_here>"
key_mgmt=NONE  #My SSID in this example is OPEN​
Sudo crontab -e #if asked use nano
@reboot sh /home/pi/wifi-to-eth-route.sh &
  • Restart raspberry pi
Nolan Herring | nolanwifi.com
TwitterLinkedIn
7 Replies 7
NolanHerring
We've dabbled with some of the IO gear, not sure what you mean by WPS being required. We set it up on a WPA2/PSK network just fine.
However the device sucked and we ended up using a Raspberry Pi instead, much better and more robust. Used it to connect some Arlo cameras to the wireless since they didn't have Wi-Fi support if I remember correctly.
TwitterLinkedIn
kYutobi
I would do what @NolanHerring suggested because you do not want WPS as a method of authentication.
Enthusiast
Karl_Jacobsen
Thanks Nolan... Do you have a link to info on the Raspberry Pi you used?
Nash
Just a quick question, is there a reason why you're not wiring the printers in and then smacking them on the same vlan as the wireless?
Karl_Jacobsen
There's no wired connections close to where they need to go. There's one or two WAPs there and nothing else.
NolanHerring
Country=US
update_config=1
network={
TwitterLinkedIn
Kamome
I'm using old Buffalo 54G router with dd-wrt firmware as wireless bridge to connect my old HP laser printer equipped with wired Jetdirect addon into home wireless network. If you have some old wireless router supports dd-wrt, how about recycle it as useful bridge?
- Supported devices : https://dd-wrt.com/support/router-database/ (Search your router model name)
- Tutorial for wireless bridge : https://forum.dd-wrt.com/wiki/index.php/Wireless_Bridge
