@Anonymous wrote:
Im looking into having 40 Mhz channels over 2.4Ghz band, is there a way to have this enabled? Any suggestions?
40mhz on 2.4ghz is really not recommended. By taking up two channels (bonding them) you are taking up 66% of the available airspace - leaving only one channel still usable. Technically, 2.4ghz has more channels available, but due to co-channel interference, in reality only channels 1, 6, and 11 are available in the US.
Meraki sets the channel width on 2.4 ghz at 20mhz - from a default dashboard, I'm not aware it can be changed. You may be able to contact Meraki support to enable it, but I wouldn't recommend it.
For higher bitrates/throughput, 5ghz is really the way to go. However it comes with its own caveats as well - remember, the more channels being bonded, the less that are available.
Here is an excellent article about some of the different frequencies: http://www.networkcomputing.com/wireless/channel-bonding-wifi-rules-and-regulations/199326059
	BHC Resorts IT Department
