- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Does Meraki MR support Dynamic WEP?
There was no mention of Dynamic WEP as an authentication in the Meraki's document.
Is it applicable in Meraki MR?
If so, could someone let me know how to configure it.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi CHGR,
I don't believe that the MR's support dynamic WEP as it's a very specific protocol. I would recommend opening up a support case and see if they're able to allow that configuration, otherwise it would be a feature request.
Cheers,
nwu1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi CHGR,
Cheers,
nwu1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi, nwu1,
Thank you very much for your advice.
I opened a case in dashboad and got reply from Meraki support team.
They said Meraki doesn't support dynamic WEP as you mentioned.
All what I can do now is just using "make a wish".
Cheers,
CHGR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No one should be using WEP anymore. Use WPA2 Enterprise mode instead.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I totally agree with you.
This is not my WLAN but someone another.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Most vendors stopped providing support for WEP as it was cracked YEARS ago. Its a very insecure method of authentication.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes, It is. Now, we omited dynamic WEP among our options.
