Disconnects on Meraki Wifi - Dynamic key exchange did not succeed within configured time
Wendy2
We are having reports of users losing connectivity to wireless in our head office for about 20 seconds, whilst stationary at their desk.
WLAN report
Wireless security failed:
Network Adapter: Intel(R) Wi-Fi 6E AX211 160MHz
Error: 0x0
This is intermittent and not experienced by all users.  Has anyone seen this and managed to resolve it?
There are reports of problems with Intel WiFi cards.
Try updating to the most current driver, otherwise you can try disabling the 802.11r SSID.
Wendy2
Logs from the NIC on the laptop are showing frequent changes between wifi_802_11ac and wifi_802_11ax
We have 2.4Ghz, 5GHz and 6GHZ enabled on the RF Profile.  802.11ax is enabled under 5GHZ.
Could this be causing an issue?
Could this be an issue?
Yes, you can, but as I said there are other reports of problems with Intel Wifi network cards.
You can do the tests I mentioned previously and also try to disable Client Balancing.
Additionally, you can try to configure the machines' wireless network card to prefer one of the bands.
https://www.xda-developers.com/how-force-5ghz-wi-fi-windows-11/
tucand
Just browsing
I encountered this situation and fixed it by resetting windows
