Disable MR auto mesh function
Jeremy-Cisco
hi,all
Would like to know if we can disable the auto mesh function,thx
OBARRERA
Now you can do it in Network -> General -> Meshing. You can turning on or off.
11 Replies 11
I don't think you can. Perhaps trying asking support in case they have something under the hood that they can do.
GiacomoS
Meraki Employee All-Star
Hi Jeremy,
The option to disable the auto mesh function is not yet available on Dashboard with the current releases.
I would echo Philip and recommend to give us a call on the support number, as can definitely work our magic for you 😉
Thanks!
Giacomo
Please keep in mind that what I post here is my personal knowledge and opinion. Don't take anything I say for the Holy Grail, but try and see!
Appreciate who helps and be respectful of every opinion and every solution offered.
Share the love, especially the Meraki one!
jameshottinger
hi,
meraki support can definitely do this. we asked them to enable it for one of our customer sites which gives you a tickbox under network-wide settings
cheers
james
Skywriter
For anybody looking for this, as I was, and couldn't find it in the Meraki Documentation (a lot about Mesh, but nothing about turning this option off). With current firmware there is a tickbox under Network-wide General config under the section "Device Configuration". You can turn the automatic mesh off.
BUT …… (very unfortunately that this option is not documented properly) …. IT WILL DISCONNECT ALL clients. I didn't notice any AP restart, but all clients lost connection for a short period of time. Very odd this happened, because there is no reason for that since both my two AP's are connected to the LAN switch.
Hellmann
This is from my own list of Meraki hidden features
CharlesIsWorkin
@Hellmann
Got it! Thanks man!
@Jeremy-Cisco
Want to come back and mark Hellmann's reply as the answer like 2 years later on this necro'ed thread? LOL.
Andrii_Oliinyk
actually it doesnt disable AP from probing in mesh. it just turn off on AP mesh repeater function
OBARRERA
CharlesIsWorkin
@OBARRERA
This is the new answer to this post. 🙂
CarolineS
Community Manager
Community Manager
Thanks, @CharlesIsWorkin and @OBARRERA! I updated the “Accepted solution” for this thread.
JessieE
Just browsing
Is there anyway I can turnoff meshing on single APs?  I have a few that goes to mesh mode, but don't them.
