Different Cipher for WPA2
route_map
Hi
Is it possible to change the Cipher from CCMP to TKIP, i know its less safer but we are testing something
Regards
2 Replies 2
Nash
I think you need to call Support and verify with them.
I'd be surprised if the answer is "yes" but I am often wrong about things.
Well, unless someone like @MerakiDave could give us a hand!
Thanks @Nash for looping me in, I can assist.  @route_map the closest you can come with the options in Dashboard in mixed mode WPA1+WPA2.  Drop me a private message and I'll get you set up via Meraki Support to enable the feature on the back-end.  Once enabled, on the Wireless > Access Control page, you'll also see a "WPA1 Only" option in the drop-down options.
Regards,
Dave
