Dashboard Monitor menu.
Gawen
Hi, newbie to the community here,
I have a task to upload floorplans of all sites with AP's installed and then map said AP's,
Having followed a simple article, in the dashboard should be able to go to Network-wide > Monitor > Maps & floor plans then upload the floorplans.
Apart from the Organisation menu no other menu's have the 'Monitor' tab, all have the 'Configure' tab.
I cannot see an article on how to enable the 'Monitor' menu, can I get some pointers on what needs to be done?
Thanks in advance.
Ryan_Miles
Meraki Employee All-Star
those top 4 are templates. those wouldn't have a monitor menu as they're just the config settings that are applied to bound networks.
6 Replies 6
BrandonS
Maybe you don't have full permissions?  Although it seems odd to have configure without monitor permission.
Gawen
Hi, thanks, that is helpful!
FWIW I have 'inherited' the dashboard, and have been granted 'Administrator' permission.
Found the oddest thing, in the main menu none of the options display the 'Monitor' menu.
However if I click on the Network menu and select an option, 'CORPORATE', CORPORATE_GUEST' and 'CORPORATE_GUEST_TECHNICS' under TEMPLATES, the Monitor menu does NOT appear.
If however I select any one of the four networks under 'Networks' the 'Monitor' menu DOES appear.
In standard best practice set up is this normal???
Gawen
Ryan_Miles
Gawen
Thank you,
Coming from a fairly new place afa Meraki, can you suggest good videos/ training media to get a solid grounding?
TIA
Brash
If you have a grounding of networking basics, navigating the dashboard is the biggest hurdle you'll face.
Once you get accustomed to it, you'll find most things logically.
There's a few Youtube videos which provide a good overview of the dashboard and how to use it.
Meraki Dashboard 101: Onboarding - YouTube
Cisco Meraki Dashboard overview demonstration - YouTube
Beyond that, I recommend taking some time to get used to where things are laid out in the dashboard.
This is especially necessary for firewall rules/ACL's as there's different places where these can be added.
Also get to know Network Wide settings and Organisation Wide settings - they're typically where you'll spend the least amount of time, but do hold some key settings that you'll likely need at a later time.
Then when you have a good idea of the specific task you're trying to achieve, the Meraki documentation is typically quite good (Google usually gets you to the right place).
