I have a user reporting a PC is "loosing connection to the wifi throughout the day". Checking the AP, I see a failed connection in the event log during the authentication stage with the reason:
reason='eapol_timeout' radio='0' vap='0' channel='11' rssi='62'
This is an HP mini PC using a USB wireless adapter (AC) with a Realtek driver. The PC is in the same classroom as the MR46. We have the same PC / AP combination in about 15 classrooms.
I have:
* swapped the USB wireless adapter between another PC that isn't having reported issues
* updated driver via Windows update
I updated the MR46 firmware to 27.7.1 today to see if that will help. Issue stays with PC. Other than re-imaging the PC, what are some other suggestions?
