Content filtering on WLAN vs LAN
ScottPR
If I have a Wireless LAN SSID that connects to the same ip range/vlan as the LAN subnet, do the LAN rules, specificly, content filtering, apply?  Basically, if I blacklist a URL on a device that has both LAN and WLAN, does it block both, or do I need to configure something to affect both networks? thanks
If you are talking about a mx. Then yes lan and wlan.
If you are talking about mr  then only wlan
2 Replies 2
ScottPR
It's an MX64, so that's good, thanks.
