@LeoG
I would like your technical opinion and experience that you already have with Meraki.
I own 5 SSIDs:
Vlan default = SSID 1
Vlan 2 = SSID 2
Vlan 3 = SSID 3
Vlan 4 = SSID 4
Vlan 5 = SSID 5 (hidden)
Only one of these Vlans I use the DHCP Meraki, in which I use for visitors with registration in the meraki portal and authentication by splash page. And this SSID I do not have to worry about roaming.
In Vlan 4 it's where roaming would have to work and it's causing me the biggest problem. This network is separate and specific for smartphones because we are users of VOIP (SIP). And users move quite a bit here being a very large company in terms of m / 2.
The image below will be in Portuguese because I am from Brazil the error is this:
When he accuses this error are those logs that I have sent there are some previous answers about disassociation errors.
My swtichs are branded Dell all with Vlan tags between Vlan default and Vlan 4. Communication works perfectly, IP addressing, etc...
The same problem is the scrolling and the reason for this authentication error.
When that happens we are at least a 5 minutes without connection, the smartphone gets lost does not know what it does. After long minutes he can connect, but always deactivating and activating the device wifi.
I already read about the Meraki guaranteeing better performance with 3 SSIDs using group polices, okay. But is it allowed to create 11 SSIDs by which they indicate use only 3? It would buy a ferrari and ride only 100km / h instead of 400km / h. Anyway, what I just did at that moment is:
Excludes Vlan 4 (smartphones). I put all my smartphones in Vlan default SSID 1 and made group rules polices for network security not to have total TCP communication with my LAN.
I own that now.
Vlan 2 = SSID 2
Vlan 3 = SSID 3
This Vlan 5 would only be for management devices in which I am already thinking about creating a new polices group for them and joining everyone in the default Vlan and thus eliminating Vlan 5. So I would abide by the Meraki documentation using 3 SSIDs on the maximum.
And after all this if the problem continues?
Do you think I'm making a mistake in everything I've just documented?
Thank you.
Pedro
Pedro Constantino
