Connection on a LAN Wireless
CarOneAdmin
Dear all,
i have a doubt with the lan wireless meraky connectivity.
if i lost internet conection,  may i can still printing, sharing documents and make connections under
all of my devices? or i lost total connection to everithing?
Regards.
yes you can. But we aware that if when you are using a cloud/internet radius for authentication of ports/wireless connection, and this also is not reachable, you will not be able to get on your network.
Do you mean the management connection to the cloud?
Your devices keep working without internet but your not able to monitor or push new configurations.
CarOneAdmin
maybe i not explain me correctly
i want to know if i lost internet connection what happen with my devices connected?
can i connect to anoher device, connect to a print & share folders, like a cable lan connection?
thanks!
If you are already connected, you will remain connected and everything will keep working.
