Configure a meraki MR33
lakshi
Hello, i just bought a cisco Meraki MR33 access point and also have the device serial number and also have an email account....all i need to know is how to configure this device when i connect the device to my laptop through a network cable?
11 Replies 11
NolanHerring
The MR33 (like all Meraki gear) just needs Internet access. The configuration for the AP is done on the dashboard. When you add the device to your organization (claim it) it should show up as being offline. Once you give it Internet access it will reach out and you'll see it come online, then it will pull down any configs you do on the dashboard for it.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
lakshi
How do i enter wifi access point name and password?
NolanHerring
The SSID name and password? Log into your dashboard first, do you see the AP online?
Here is a quick start guide:
https://documentation.meraki.com/MR/MR_Quick_Start
TwitterLinkedIn
lakshi
this is my dashboard screen that shows wifi name PAPITA_DOWN which i need to change, also change password..pls guide medashboarddashboard
NolanHerring
That screenshot looks strange. I don't see any menu options on the left side.
You should see this wireless tab underneath the network you created and added the AP to.
TwitterLinkedIn
lakshi
i reseted the device by holding the reset button and i have not connected the device to the net...is that why i dont see the menu on the left side?
lakshi
This device was setup by a technician in my absence and i wanted to change wifi name and password....how do i do that?
NolanHerring
Did you purchase a license with the MR33? It won't work without it. Not 100% sure why your not seeing any menu options but my best guess is that you have no devices on your Org/Network. You can't configure this AP unless it is claimed and added into the Org your logged into.
TwitterLinkedIn
lakshi
Ok, i will contact the technician who configured it
ask your tech guy to make you admin. looks like your in some monitor only mode
lakshi
ok ill do that...
