Client could not associate with the WIFI getting error reason='invalid_mdie'
Amir_Khurshid
Hi Team,
I have a Printer which got disconnected from Network and then it tries to connect to Multiple AP's within a span of seconds. It tries but never pass association step and the logs shows reason='invalid_mdie'.
Connection start time Client device SSID Failure stage Failure reason
Thu May 30, 2024, 16:58:22WEGENP010HeadlessAssociation
auth_mode='wpa2-psk' 11k='0' 11v='1' reason='invalid_mdie' radio='1' vap='2' channel='112' rssi='32'
Thu May 30, 2024, 16:58:11WEGENP010HeadlessAssociation
auth_mode='wpa2-psk' 11k='0' 11v='1' reason='invalid_mdie' radio='1' vap='2' channel='112' rssi='31'
Thu May 30, 2024, 16:57:39WEGENP010HeadlessAssociation
Thu May 30, 2024, 16:57:21WEGENP010HeadlessAssociation
auth_mode='wpa2-psk' 11k='0' 11v='1' reason='invalid_mdie' radio='0' vap='2' channel='1' rssi='39'
Thu May 30, 2024, 16:57:05WEGENP010HeadlessAssociation
Thu May 30, 2024, 16:56:39WEGENP010HeadlessAssociation
auth_mode='wpa2-psk' 11k='0' 11v='1' reason='invalid_mdie' radio='0' vap='2' channel='1' rssi='45'
Thu May 30, 2024, 16:56:23WEGENP010HeadlessAssociation
auth_mode='wpa2-psk' 11k='0' 11v='1' reason='invalid_mdie' radio='1' vap='2' channel='112' rssi='30'
Thu May 30, 2024, 16:56:04WEGENP010HeadlessAssociation
auth_mode='wpa2-psk' 11k='0' 11v='1' reason='invalid_mdie' radio='0' vap='2' channel='1' rssi='43'
Thu May 30, 2024, 16:55:40WEGENP010HeadlessAssociation
Thu May 30, 2024, 16:55:08WEGENP010HeadlessAssociation
2 Replies 2
Are you using a network with the correct PSK? How is WPA encryption configured? I suggest leaving WPA2 only to test. Also, how are the minimum bitrate configured in your RF profile?
From what i read it could be related to
802.11r
Do you have that enabled on the ssid?
Also, try update the client drivers /firmware
