Hi @MrTaylor ,
I've had MRs go funky in the LAB. But I always verify with a known working switch/cable that provided PoE to another device. Once I've established that, I know the port is faulty.
If your MR56 is connnected to a Meraki Siwtch, you can run a cable test on the connected port. This would show any issues as well..
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
