APs are sending Disconnect-Ack without disconnecting clients
ArnoldD
So i've run into an interesting issue.  We have a guest portal configured on ClearPass, which sends a COA disconnect request on port 3799.  Yesterday, we noticed that guests were still locked within the walled garden after authenticating.  After looking at a packet capture, the connection looks as expected: Guest signs in, CPPM send disconnect, AP sends disconnect-ACK... but the client is still locked.  Reauthenticating manually works, since the client is already registered.
My question is: Why are my APs all of a sudden unable to disconnect clients via COA, and most importantly, why are they sending the disconnect-ACK, when the client is clearly still connected?
Have you had a recent firmware update?
ArnoldD
No updates.  I'm thinking meraki may suggest one.
TBHPTL
Open a case with Cisco Meraki.
EMU_IT
I'm facing the same issue, and I'm curious how this was resolved for you?
Thanks.
