Can't connect AP MR44 to Meraki Dashboard, while get an native vlan from MX67W
Mikhailkevin
Hello everyone good afternoon!, i can't connect my AP to meraki dashboard, even tought get the IP from natuve vlan 1 from MX67W inside port 2. Howbto solve this? Thank you 🙏🏻
DarrenOC
Well done for resolving @Mikhailkevin
a reset shouldn’t be required if this was a brand new fresh out of the box AP.
DarrenOC
Morning @Mikhailkevin, what are you seeing in your pcap that you’ve run on port two of the MX?
Mikhailkevin
Thank you for mention me darren, about this problem is solved, because the first thing to do with the ap it must to reset then hold 15-20 seconds. After that the ap led is blinking blue, and when the led is green. It successful  connected to Meraki Dashboard. Thank you very mush for responding 🙏
DarrenOC
