Can i connect a PC in the second ethernet port of a Meraki MR84 ?
josegura42
Can i conect a PC in the second ethernet port and recieve internet in that way?
I have a PC and i want to connect to the internet with a wired connection to the MR84
AjitKumar
I understand this shall not be possible.
Please check the following Url for more information.
https://documentation.meraki.com/MR/Installation_Guides/MR84_Installation_Guide#Ethernet_Port
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
9 Replies 9
AjitKumar
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
BrechtSchamp
Actually I think you can. There's a setting in network wide/general that allows you to set what happens to clients wired up to APs. If you contact Meraki support they can also activate port profiles for other models than MR30H.
That setting is when the MR is operating in mesh mode, and it causes it to bridge the LAN from a remote mesh node.
BrechtSchamp
Okay, I haven't tested it so I'm not sure.
That said, the beta feature is definitely available to use the secondary wired port for clients. It's documented here:
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/Port_Profiles
But as mentioned earlier you need to get in contact with Meraki support to enable it.
MerakiDave
Correct, you may use port profiles for this functionality.  Port profiles are available by default on the MR30H AP, and it's the same mechanism on APs with 2 physical ports (MR52/53/84 today).  The AP must not be a mesh repeater, and the feature needs to be enabled by Meraki Support.  Hope that helps!
NolanHerring
"and the feature needs to be enabled by Meraki Support"
Dear diary,
I hope one day that Meraki will release a list of all of its wonderful hidden features for us common folk.
-The End
Nolan Herring | nolanwifi.com
TwitterLinkedIn
Cmiller
I second this... make this an option for the CMNA/CMNO cert holders and the certs will have more value.
An MX84 has a single WAN port.   So the second port for a referring to is a standard LAN port (unless changed via the local status page).
So as long as it is all appropriately configured then a PC can be plugged into it.
Oops,  i misread this as MX84 instead of  MR84.   @AjitKumar  is correct.
