Bridge Mode AP to AP to Meraki Switch
WPOOLEIEC
I'm trying to use two MR53e Access Points in Bridge mode to continue my network to a part of the building I can't run cable to.
The plan was to have MR53(a) connected to my Switch(a) broadcasting BridgeSSID. Then have my Other MR53(b) connected to Switch(b) in the uplink port with BridgeSSID as a Trunk to get all my VLANS on Switch(b).  Since MR53's have two ports, I was planning on using 1 port for the poe and the other for the network connection.
Will this work?
Walter
2 Replies 2
You would normally power the MR53 via the switch.  If you can't do that you should use a power injector or a power cube.
Refer to this design guide, especially the Ethernet bridging section.
https://documentation.meraki.com/MR/Deployment_Guides/Mesh_Deployment_Guide_(CVD)
BrandonS
Sadly this won't work.  You can only bridge a single VLAN with MR's.
The good news is there are plenty of capable bridges out there to choose from for as low as $100 for a pair.
