Blocking Devices on Meraki portal without admin
Yarig
Hi everyone,
I have a requirement that is proving difficult to fulfil and I lack the access to confirm what is possible, so I'm hoping the community can help, or at least confirm what is possible.
I work in a security team and we see alerts showing some devices contacting malicious domains. These are connected to a Cisco WAP and discoverable on the Meraki dashboard search.
I want to create a way for these devices to be blocked, but my request ended up being denied as I was told that this action requires full admin rights on the portal.
Is this the case? Is there any method that could be used to allow a device block to be applied without needing full admin rights?
5 Replies 5
Make_IT_Simple
Meraki Alumni (Retired)
That's not possible, to make any change in Meraki Dashboard, you need to have full org access.
Make_IT_Simple
Yarig
Hi @Make_IT_Simple
Thanks for confirming that. I can at least put the topic to rest and move on 🙂
Yarig
I checked that link and noticed that one role may fit the bill in a sense:
Guest ambassador: User only able to see the list of Meraki authentication users, add users, update existing users, and authorize/deauthorize users on an SSID or client VPN. Ambassadors can also remove wireless users if they are an ambassador on all networks.
If we had the ability to kick a device off the network then that would be something we can do, but not have full org admin. Am I misunderstanding that role?
Make_IT_Simple
I don't believe that option will work for you. Just for testing, I did try that in my own dashboard and I couldn't do much with a guest ambassador user.
