Time scheduled switch on/off
TRS_ICT
Morning
I can' find anything on this - but maybe i'm looking wrong.. but i've been asked if there is anyway, within the Meraki portal to disable a specific SSID during certain hours?
Or if not, any suggestions or a workaround - such as disable the port (the AP's are connected to Cisco MS120 switches) and re-enable at certain times?
Any ideas would be appreciated.
KarstenI
You can control the SSID under "Wireless -> Configure -> SSID Availablility". And yes, you could also switch off the switchport with port-schedules.
If you have a management server, you can enable/disable deep sleep of the APs through the API.
2 Replies 2
KarstenI
