Authentication with Google Credentials
-Andrea-
I am looking for a way to allow us to use Google credentials to login on an SSID. I know that there is a way to setup Google splash-screen but that would be cumbersome for daily use and we would like instead to rely on Google username and passwords to login on the wifi so that can be saved and maybe even allow 2FA to authenticate on the network.
any suggestion would be appreciated.
8 Replies 8
BrandonS
I am pretty sure you can ask support to enable this for you. Maybe with beta or not official support disclaimer.
What should I ask for? is there a particular product/feature to request
BrandonS
check this
I tested That but I causes a splash screen that keeps coming back every so often for whatever reason.
BrandonS
I never tried it myself so can’t be much more help. Maybe share the link with support and see what they have to say?
I am calling support right now 😉
I have the same problem, did you get the solution?
Unfortunately meraki does not have that feature.
