Association errors
Alex123
Association errors
Hi all,
I'm having some issues with client association errors on our dash for our new network:
auth_mode='wpa3-psk' 11k='1' 11v='1' reason='reserved' radio='2' vap='4' channel='85' rssi='46'
Seems to occur on an initial connection and sometimes when roaming. The issue only occurs on 6 Ghz - If we disable 6 Ghz on the client and fall back to 5 Ghz, there is no error.  Disconnecting/reconnecting to the network triggers the error.
Looking at wireshark, there doesn't appear to be anything out of the norm (4 Packets Authentication, 2 Packets association, then 4 packets for handshake):
Authentication, SN=356, FN=0, Flags =.
Authentication, SN=396, FN=0, Flags=
Authentication, SN=357, FN=0, Flags=
Authentication, SN=397, FN=0, Flags =.
Association Request, SN=358, FN=0, Flags=
Association Response, SN=0, FN=0, Flags=
Key (Message 1 of 4)
Key (Message 2 of 4)
Key (Message 3 of 4)
Key (Message 4 of 4)
<DHCP stuff>
From a performance perspective, the error isn't noticeable on the client. There is also nothing of note in the WLAN report.
We're running MR 30.7.1 /  CW9166I APs / WPA3-SAE / Intel AX211 (also had same issue on Netgear A8000)
Any ideas?
18 Replies 18
WPA3 is difficult to get going, full stop.  This is because of client side issues.  And now throw 6Ghz into the mix - it is note really suitable for production roll out yet.
It is nearly always buggy client side drivers.  Start by driving to update the WiFi drivers on whatever the device is.  Don't be surprised if it takes another couple of years before you get drivers that work reliably.
VivekT
Hi ,
Are you using this mode of wpa3 ?
PSK (WPA3-SAE Transition Mode)
macnerd
hi, our Cisco 9164 and 9162 are having the same exact error
our meraki dashboard states that “our Intel ax211” clients are experiencing “failure to associate”
we tried using 5GHz only with wpa3-sae, no issue
but when we only use 6Ghz only with wpa3-sae, the issue occurs
the behaviour is the same with @Alex123 the error occurs when users 1st power on their laptop and did a 1st time connect with our ap
and it will occur also when our clients are roaming
Alex123
We are running WPA3 only (no transition mode)
VivekT
Can you please try PSK (WPA3-SAE Transition Mode)? We were having similar issue with Meraki Mr57. Post switching from wpa3 only to Transition Mode , now the connectivity is more stable with 6Ghz.
macnerd
hi @VivekT
according to meraki documentation, if we need to use 6Ghz, we can't use wpa3 transition mode
we have tried also, it can't connect
for wpa3 personal, our option is only pure wpa3-sae
we can't go wpa3 enterprise either
VivekT
This is what I can see on our dashboard :
When WPA3 is selected, 802.11w is automatically set to required. If any APs broadcasting the SSID do not support WPA3, they will default to WPA2 authentication instead.
WPA3 only : This options comes when we use radius authentication.. The below should be get enabled automatically
802.11w
  • Enabled (allow unsupported clients)
  • Required (reject unsupported clients)
  • Disabled (never use)
If we use PSK .. then we should see WPA3-SAE Transition Mode.802.11w is automatically required
I have MR57 , it works well without any issue.
Alex123
Hi VivekT,
When trying to use WPA3 transition mode on 6ghz, I get the error message below:
This SSID will not broadcast on the 6 GHz band. Use WPA3 to enable this band.
Meraki support have recommended to move to the latest stable candidate firmware. I'll report back in a couple of days when I am able to upgrade/test.
Alex123
No luck with MR 31.1.5.1
AnthonyN
Hey Alex
If your also getting the same errors on other AP's then it is likely a client side issue. Have you updated your wireless drivers to the latest firmware? Might be worth raising a ticket with your vendor.
Alex123
Yeah already running latest drivers. Also occurs when live booted into ubuntu.
It's been escalated to the meraki devs. In the mean time we're moving to WPA3-Enterprise to get the project finished.
macnerd
hi,
sorry for this delayed reply
was doing testing
we are running 30.7.1 for meraki
we found that even laptop was station and it didn’t jump AP, the failure will occur
we are in contact with meraki
we have asked their help to do simulation at their eng lab to see if they can replicate this behaviour
the intel ax211 driver that we are running is v23.90 which is the latest
we fresh install windows and let Microsoft auto install the WiFi nic driver, it’s installing v23.60. > same behaviour
we tested dell’s driver, the latest is v23.60 > same behaviour
BaskaranGanesan
i have the same behaviour in our environment, Slight change in the MAC and Windows laptops are causing issues on roaming between AP and getting latency and packet drops
macnerd
i see,
may i ask, have you found a solution for this problem?
BaskaranGanesan
Not Yet. We're still working with TAC. Almost did everything possible at the AP and Network driver ends. nothing helped out.
macnerd
We are the same, also in contact with TAC. Previously we tested, iPhone and Android, same issue, we think it’s may not be related to Windows OS drivers
BaskaranGanesan
Here we have Intel AX211 6E 23.120.0.3, the majority of users are causing issues
macnerd
@BaskaranGanesan
on the 15th last month, mr31.1.7 was released as release candidate. in the changed log, there is a mention of <code 0 : reserved> being fixed. we upgraded but we are still having the same behaviour.
drivers version that we have tested :
these are the drivers that we tested until we found that Apple iOS is exhibiting the same behaviour previously.
22.120 : totally unable to detect 6GHz band
22.130 : totally unable to detect 6GHz band
22.140 : totally unable to detect 6GHz band
22.150 : totally unable to detect 6GHz band
22.160 : totally unable to detect 6GHz band
22.170 : able to detect 6GHz band but exhibit the same behaviour
22.180 : able to detect 6GHz band but exhibit the same behaviour
22.190 : able to detect 6GHz band but exhibit the same behaviour
22.240 : able to detect 6GHz band but exhibit the same behaviour
23.50   : able to detect 6GHz band but exhibit the same behaviour
after we upgraded to mr31.1.7, we tested the 23.130.1, Intel latest. same behaviour
