Association error_code='31'
Dunky
Can anyone tell me what error code 31 actually means, I cannot find any reference to it online.
This is the failure reason I am seeing in the Connection Log:
auth_mode='wpa3-psk' 11k='0' 11v='0' error_code='31' radio='0' vap='0' channel='1
GreenMan
Meraki Employee All-Star
GreenMan
Did you install the latest drivers for your wifi chipset?
https://www.wintips.org/fix-network-adapter-code-31-device-is-not-working-properly/
Dunky
Thanks, I will attempt to find out, although all I have are MAC addressed, its not showing the host names which may make it difficult to track them down.
Dunky
I've marked this as the solution solely to keep the board from having unresolved topics.
We are still trying to identify what these 2 clients are, each are failing association approx 2,800 times/24hrs!
