- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
How Can I See Bulk MAC Address?
Hello, I am an IT Specialist in an educational institution. The institution has MR36, MR36H access points. About 400 devices are connected, I want to list the connected devices on the Meraki dashboard in bulk, how can I do it? it becomes very difficult to list for each device in the dashboard
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
In the Dashboard under Network Wide -> Clients, you can see the table of connected clients.
Clicking the spanner on the right hand side, you can add a column for MAC Address.
If you're only wanting to see wireless clients, you can click the dropdown button in the Search field, and filter on Client Type -> Wireless.
Should it be required, you can then export this as a CSV.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
