Apple TV and Meraki MR56
JMLOSD
Is it possible to have an Apple TV or Airtame (wireless display device) be associated to a specific Meraki WAP?
8 Replies 8
The only possibility is for you to create a unique SSID for this device and advertise it soemnet on the target AP.
https://documentation.meraki.com/MR/Other_Topics/Using_Tags_to_Broadcast_SSIDs_from_Specific_APs
KarstenI
Is there a specific reason for this? In general, I would say it is not the optimal solution.
JMLOSD
This is an issue mainly in my middle and high schools. Because there are so many classrooms that have Apple TVs, it takes a while to scroll and find the correct one when the Apple TV has been rebooted or updated. Most of the classrooms have their Apple TV advertised to connect easily, however, in those instances where is it not showing, scrolling takes time to locate and sometimes it takes a couple of refreshes to connect. I was thinking that it may be easier if the Apple TV is associated to the Ap in the classroom for easier searching and connecting.
Not really, maybe you have another problem (like the wireless network design).
JMLOSD
Each classroom has an WAP. How should I change the wireless network design?
It would be interesting to hire a specialized company to carry out a site survey and validate your wireless network.
Put each classroom into a seperate VLAN, so the people in the classroom can only see the assets located in that classroom.
If you use PSKs rather than a username/password to attach, you could also use WPN to create a virtual WiFi network per classroom.  This has the same impact as using VLANs, without having to create a VLAN, but provides easier roaming.  This article discusses using WPN in a school environment.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Wi-Fi_Personal_Network_(WPN)
chuyendang
We have over 200 AppleTVs in our campus. I disable Bonjour to block AppleTV broadcasting over network. Clients will be able to find the nearby AppleTV via Bluetooth.
