Alert for connection speed drop on MR36 WAPs
TimButterworth
Hi there,
I recently discovered that a small number of our WAPs that should be connected to the switches at 1000 Mbps are showing as 100 Mbps in Meraki console. I've looked through the available alerts and can only find ones that alert if the gateway goes offline or becomes a repeater. Does anyone know of a way of setting up alerts so I'm notified next time this happens?
Thanks!
TBHPTL
Assume you meant dashboard as there is no usable console on Meraki....
Do this on the Switch...
  • tag the switch port with something like 'WAP' etc
TBHPTL
Perfect @TBHPTL, this is exactly what I do 😊
TimButterworth
That's great, thanks for the advice.
