AP Tag via API
Mamba123
AP Tag via API
Hi guys, I have a question.
Is it possible to create a tag via API and add specific APs to this tag?
Unfortunately I have not found any information about this on the net.
Thanks.
You don't add APs to a tag - it is the other way around.  You assign a tag to an AP.
https://developer.cisco.com/meraki/api-v1/#!update-device
Tiro
Just browsing
what is the path to assign tag please?
I can only find it for SM not AP
SandroZ
Hi @Mamba123
if you are searching for an API to create TAGs is not needed, you can use the API call suggested from @PhilipDAth and add all the TAGs you want 😊, they do not need to be created before being assigned.
Have a great day!
Sandro
