AD Authencation
ganeshjadhav
AD Authencation
we are using Meraki MR and MR intregate with our AD server, If i forgot this SSID and re connecte again then it will direct connect to the internet, Its not asking to username and password
Nope, you need to re-authenticate again.
@ganeshjadhav can you share how you have configured the SSID as that doesn't sound like it is working as it should?
I'm guessing you are using splash page authentication.  When you use this method, it grants authentication based on the device MAC address.
Forgetting the network and adding it again to your phone doe snot change your phone's mac address - so you remain authenticated.
