A new AP - CW9166D1?
Today I noticed a new AP model (new to me at least) which is described as a version of the CW9166 with directional antennas that focus most of the reception in front of the AP across an arc of about 70 degrees.  It also seems to be certified down to -20C operating temperature (-4F for west pondians)  You can see the differences in the spec linked to below:
CW9166 Datasheet - Cisco Meraki
Has anyone received one of these and are they for outdoor use with such a low temperature rating?
12 Replies 12
DarrenOC
Are they turning the heating off in the Casinos?
Only if you don't pay your debts... 😉
KarstenI
They are not for outdoor use as this is not yet allowed by the regulations. But IMO it could be a good successor (if budget permits) for an MR46E with a patch antenna.
As mentioned by @KarstenI  they are not for outdoor use.
KarstenI
Info on the CW9166D1: https://soundcloud.com/user-327105904/s10e25
DarrenOC
Thanks @KarstenI - I didn’t know that Cisco Champions were on SoundCloud.
Good find.
amabt
Has anyone actually deployed the CW9166D1 in a warehouse. We have a project and Meraki are suggesting them as an option.
KarstenI
The beamwidth should be too wide for the typical warehouse use-case. I still would like to hear it if someone has used them in a warehouse.
UKDanJones
I’m just using them for a design right now!
Please feel free to hit that kudos button
TBHPTL
Double check the datasheet no NEMA or IP ratings and that's not operating temps that storage temps..  But it does shave a significantly more robust operating range then say an MR53.
amabt
We are being sent a couple to play with. I will report back once we have done a bit of testing in a warehouse of ours.
