801.x bypass
piasterloo
801.x bypass
Folks ,Is it possible to bypass 802.1x authentication for a wireless client (iPad) in Meraki ?
Yes, It is, you need to use the allow list.
I'm sorry for the wrong information, I just realized it now.
ConnorL
Meraki Employee All-Star
A client still needs to authenticate to the SSID before any Allow/Deny lists come into play. Adding the client to the allow list would simply bypass any splash or firewall settings.
You'll need to create a separate SSID, however seeing as iPads do support .1x auth, what's the user case you're attempting to solve here? Cert based auth for devices like iPads works well.
TBHPTL
100%, you can't bypass 802.1X that happens before an IP is issued. Any bypass like MAB would have to be on the actual RADIUS server...
