6GHz benefit
6GHz benefit
I just happened to test the wireless performance when I'm connected to a CW9166I with a very low signal, as my experience seemed fine, and it's actually pretty good:
GIdenJoe
Well with that low an SNR you probably got an MCS of 3.  That should mean you got about a PHY rate of 144 Mbps since you are using an 80MHz channel (probably a 996 tone RU).
KarstenI
6GHz is the game changer!
Paccers
Not even at full capability either with 80 vs 120 MHz chan. width
GIdenJoe
