Nov 20 2024
6:14 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Nov 20 2024
6:14 PM
Deploying nee SSID across multiple templates with multiple networks
Deploying a new SSID across 30 templates with multiple networks in different states. Was wondering if their is a way to populate the new SSID to all templates other than manual entry.
1 Reply 1
Nov 21 2024
1:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Nov 21 2024
1:10 PM
You would need to use the API. Their are a number of pre-written automaton scripts - you might be able to find one close to what you want and then modify from there.
https://github.com/meraki/automation-scripts
You can find the Dashboard API documentation here.
https://developer.cisco.com/meraki/api-v1/
