2 SSID 1 VLAN
JED2021
2 SSID 1 VLAN
I have a SSID VLAN/ SUBNET  / DHCP pool (/4). an isolated environment
The SSID supports 2.4 and 5GHZ
some legacy devices per the vendor should be on 2.4 only.
Is it possible to create a new SSID ( supposedly Meraki support can enable 2.4 only config). that uses the same VLAN and DHCP pool.  I do not want to separate  these devices since they communicate to other LAN based systems on that VLAN for monitoring
2 Replies 2
Sure
Absolutely, if the DHCP is provided from the LAN and not the AP itself, if from the AP then I think not.
