tried it in an older Post, but believe no one will recognize 😉
https://community.meraki.com/t5/Wireless-LAN/WiFi-devices-disconnecting-all-the-time/m-p/43042#M6644
I have got the problem, all devices connected to the Guest Wifi are getting disconnected after several minutes / hours.
There is nothing configured you have to re-auth after x-minutes. As I am streaming music, for testing, I do make traffic, so this shouldn´t be the case I´m getting disconnected.
Also tried 5GHz band only, same problem.
Any ideas?
Solved! Go to Solution.
Do you use a splash page? Did you check the splash page frequency? Just wondering it could be that or try to adjust the time a little higher see if it fixes it.
The log entries actually show that the splash page frequency is configured to one hour (3600 seconds). Look at each line that shows a Splash Authentication.
As suggested by @kYutobi , you should modify the Splash Page Frequency setting.
oh my god, this is so embarrassing :S
Can´t remember I set it to 1hour, or even configured it.
Thanks to all.
No problem man. It's these little settings that drive us crazy sometimes.
@MarcP wrote:oh my god, this is so embarrassing :S
Thanks to all.
did you filter this log?
you only have one AP?
did you also try without splash page?
