WMM setting on Meraki MR
CHGR
I have read Meraki MR supports WMM.
Could you let me know how to enable/disable this function?
Besides, I want to set WMM as below.
WMM AC_vo --- dscp 56
WMM AC_vi --- dscp 40
WMM AC_be --- dscp 24
WMM AC_bk --- dscp 8
Could you let me know how to set it?
3 REPLIES 3
CHGR
Hello. Could you correct me if I have misunderstood.
Meraki MR supports WMM and WMM is function to prioritize the traffic.
There is no way to change or I don't need to change dscp for 4 catefories of traffic as AC_vo, AC_vi, AC_be, AC_bk because Meraki AP will define which traffic belongs among AC_vo, AC_vi, AC_be, AC_bk and Meraki has already difine which traffic needs to be high priority.
If I turn on "Enable default traffic shaping rules", WMM will start working. When I want to disable WMM, I need to choose "Disable default traffic shaping rules".
Is it correct understanding?
P.S. Aruba WLAN controller can change the dscp for WMM. So I got confused why Meraki can not change the dscp for AC_vo, AC_vi, AC_be, AC_bk.
Yes and yes.
