How to Set SSID Visibility true API
MichelRueger
Hi Meraki freaks,
Does somebody know how to set the SSID Visibility true Dashboard API? for exaple with Postman?
Thanks for any Help on this
1 Reply 1
NolanHerring
The only API that exists for updating an SSID is as follows:
"name": "SSID_NAME_HERE",
"enabled": false,
"splashPage": "None",
"perClientBandwidthLimitUp": 0,
"perClientBandwidthLimitDown": 0,
"ssidAdminAccessible": false,
"ipAssignmentMode": "NAT mode",
"authMode": "open"
However, I know there are more options because when I GET for any specific network I have, the results yield many more options.
Example of a WPA2-Enterprise network:
"number": 0,
"name": "TESTING_123",
"enabled": true,
"authMode": "8021x-radius",
"encryptionMode": "wpa-eap",
"wpaEncryptionMode": "WPA2 only",
"radiusServers": [
"host": "10.10.10.10",
"port": 1812
"host": "10.10.10.11",
"port": 1812
"radiusAccountingEnabled": true,
"radiusAccountingServers": [
"port": 1813
"port": 1813
"radiusCoaEnabled": false,
"radiusAttributeForGroupPolicies": "Filter-Id",
"radiusFailoverPolicy": null,
"radiusLoadBalancingPolicy": null,
"ipAssignmentMode": "Bridge mode",
"useVlanTagging": true,
"defaultVlanId": 208,
"radiusOverride": false,
"minBitrate": 24,
"bandSelection": "5 GHz band only",
So I just tested this on an SSID that has Visibility set to 'Advertise this SSID publicly'
And I got these results:
"number": 3,
"name": "TEST",
"enabled": true,
"authMode": "psk",
"psk": "testing1234",
"encryptionMode": "wpa",
"minBitrate": 6,
So then I changed it to 'Hide this SSID'
I don't see any change in the GET unfortunately.
The Meraki API is very much still a work in progress, and they are updating it overtime but it is still lacking very much.
Nolan Herring | nolanwifi.com
TwitterLinkedIn
