Meraki Cloud Authentication question
Keith_Li
Dear All,
               I would like to ask if i want to use sign-on with "Meraki Cloud Authentication", just wonder is this approach not approicated for walk-in customer use in the store ? since i need to create credential (e-mail and password) for customer, our customer purposed they would like customer to connect to the guest-wifi and enter the password in the same page of landing page, any help would be appreicated
Keith
Well, sorry but what are you asking for is not possible.
10 Replies 10
Brash
Meraki Cloud Authentication doesn't seem like it's the best option for your use case.
You could leave the guest wifi open , or If you need to secure it, you could simply use WPA2-PSK.
Is the Sign-on with with Facebook or Google an option?
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Facebook_Login
Do you need the customer to sign up?  How about a simple splash page they can just click "continue" on?
Keith_Li
our customer would like the enter the password within the splash page rather than to have password page popup before the splash page, just thinking if there is other method to fulfill customer need
Ok, but it doesn't increase security if it's the propose.  You can try with billing.
https://documentation.meraki.com/MR/MR_Splash_Page/Billing_for_Wireless_Access
But in my opinion 802.x always will be the best option.
Keith_Li
does it has the sample can see how its look if using billing ?
An example of what fast pre-paid billing looks like is in the link I provided:
https://documentation.meraki.com/MR/MR_Splash_Page/Customizing_Splash_Pages_for_Fast_Prepaid_Card_Bi...
Depsite the word "billing" in the name - no billing is required.
Keith_Li
just realized billing is not the one our customer want
You can use pre-paid billing in "fast" mode.  You set the billing price to $0.  You then pre-generate a bunch of the codes (say 100), print them out on little slips of paper, and give them to the guests if they want to use WiFi.
