Meraki APintermittent cuts
athan1234
Hi everyone
I have a network with 45 AP.s . Sometimes some AP they get be down .  I guess it can be gets for the interferences or similar cause .
I attach you my reports sometimes I should fix some RF
This is the AP 79% very high
Any idea as I should improve this situation .
AP Maps
DarrenOC
Honestly, I'd get a professional in to run a wireless survey otherwise you're going to be chasing your tail and trying to tweak settings left, right and centre.  The cost of which would cover the survey.
DarrenOC
BrandonS
I agree you really should get a site survey and then can determine what is going on with channel utilization and interference.  What do you mean, "..some AP they get be down" though?  that may be a different issue like cable or power, etc?
athan1234
Ok , thanks
