Hi All,
Looking for an official answer on the MR74 and the MA-ANT-23 antenna.
Looking at the current on line Datasheet, this is not mentioned:
MERAKI MR74 Datasheet
However I've found an old one (attached), that does confirm that is is compatible (from 2017):
It's a direct request from the customer, perhaps a solution used before, however double checking these things is good practice of course.
The MR74 has 4x N-Type Connectors where as the MA-ANT-23 only has two cable N-Type Out connectors for the AP.
Can anyone advise please?
It may be the case the the MA-ANT-23 may work, however not advise due to reasons X, Y and Z.
Ian
