MR radio settings
Awallace
MR radio settings
is there a way that you can 2 or more sets of radio settings and or splash page rules based on the time of day ?  Shy of having multiple SSIDs  with the same name that turns off at 8pm and the other that starts up at 8pm. ?
<al>
The script would be using the API, so to automate it you would set it up to run automatically from a computer somewhere. I think it would be easier to set up two different SSIDs though.
8 Replies 8
i think you have to build a script/ API to disable one ssid and enable the other.
Awallace
where would you apply the script? and is there an example?
(MR 18)
<al>
are there examples that you know of that could be used?
SSID Variation examples? You could do something like "Company Guest" and "company guest" or "Company guest".
Well I guess it's time for the API load.  Thank you all.
<al>
I would try the multiple SSID approach - but I'm not sure you'll be allowed to define two SSIDs with the same name.
@PhilipDAth that's right, the dashboard will error out if you attempt to have two SSIDs with the same name, it is case sensitive though so you could have a very minor change between the SSIDs.
