MR 44 goes into repeator mode
Keith_Li
Dear All,
          2 of our MR44 AP goes into repeator mode, having check in to meraki switch side and run a cable test button, the pair 4 show open, does it means it is related with bad cable issue ? having checked the Poe useage, it is still under usage, any idea ?
Port Link Length Status Pair 1 Pair 2 Pair 3 Pair 4
8down48.75 mOKokokokopen
PoE usage
CONSUMPTION
134.9 W / 740 W
BUDGETED
510 W / 740 W
keith
MerakiDave
Yes @Keith_Li , that is indicating a L1 issue and should look to replace that cable, the AP is unable to make a sufficient wired connection to the LAN and is automatically leveraging repeater mode to keep itself online and keep serving clients.
MerakiDave
Keith_Li
noted, and i will try to ask our cable vendor to check the connection first, thanks for your reply
EJN
An easy first thing to try is to redo the two ends of the cable (assuming it's a custom length cable). If prebuilt, then just change the cable.
Esteban J Nunez
School and Church
K-12 Education
Keith_Li
problem has resolved by replaced lan cable, thanks
