How does speed affect the velocity test?
athan1234
Dear all:
When my client tests the internet speed, there are a AP zone some AP in where the test speed is lower than the rest of the AP´s.
I saw in the topology that the major connection between the APs, whose test velocities are lower, is 10 G
The remaining area is where the AP's regular test velocities is the 20 G.
Do you think it would be an issue ?
I am aware that there are some circustancies, though RF
KarstenI
With this little traffic it is quite certain that having "only" 10G is not the problem. Moving to 20G with a LAG will improve reliability but will not solve the problem. Now you have to look for other differences between these two places. For example AP config/models/problems/channels etc.
6 REPLIES 6
KarstenI
Look at the dashboard if these 10G links are already saturated. If yes, not only the speed-tests are affected, also the user-experience should be limited.
athan1234
@KarstenI  thanks for yor reply
Where on the dashboard can I look?
So I suppose it is all the total traffic, and I want to know how much traffic there is in this region overall.
If you look at my screen shot, the traffic usage is 782 Gb on one side and 574 Gb on the other.
KarstenI
You need to look at the individual ports that connect your switches:
If you see a traffic rate that approaches the line rate it's time to add some links to the LAG or move to a faster interface.
The pure amount of traffic is not really relevant as it doesn't tell if it is bursty.
athan1234
Thanks I will check it
athan1234
I'm examining the ports, but it doesn't seem to be the issue?
Is it not?
KarstenI
