Best practice for AP port configuration
Turimo
My wireless data is managed by Meraki AP. On the port that connect the switches to the AP, I've configured my port as trunk,  STP guard as BPDU Guard since from what i understand Meraki AP don't send BPDU but i was wondering if it was wise to setup storm control on AP ports or if it should not be done.
Hope you can advice.
Thank you.
Turimo
5 Replies 5
I never configured the STP BPDU guard on the AP ports,Best Practices to enable BPDU Guard only on access ports (access ports lead to end user devices), but I always configured the storm control, some think like this:
storm-control broadcast level 20.00 10.00
storm-control multicast level 20.00 10.00
storm-control action shutdown
spanning-tree portfast trunk
RaphaelL
BPDU Guard is safe on trunks leading to Meraki APs. It is indeed wise to configure it since these APs do not participate to the STP topology.
Storm control is fine but setting high values defeats the purpose.
@RaphaelL
BPDU guard is enabled globally on all STP portfast ports with the command spanning-tree portfast bpduguard default.
BPDU guard is typically configured with all host-facing ports that are enabled with portfast, but it is not very common to see configured on AP ports.
RaphaelL
I'm not sure why you provided IOS commands , but the only downside of enabling bpdu guard on AP ports is that someone could send a bpdu and the port would go into 'err disable' state which would 'DOS' that AP.
It also prevents someone from unplugging the AP and plug a switch since Meraki do not support 802.1X auth on trunks so you don't have any other way to protect your network from that behavior.
Some enterprise prefer 'security' over user experience.   I have mixed feelings over bpdu guard on AP but it can be done.
Also if you use SecurePort ( RIP SecureConnect ) it will not override STP settings , so It would keep the bpdu guard from an access port.
EDIT :
TLDR : There is no good or bad answer to configure bpdu guard on Meraki AP ports. That's my opinion. Some may agree / disagree
It doesn't matter if is Meraki Switch or Catalyst Switch.
BPDU guard
BPDUs - Bridge Protocol Data Units - are informational messages communicated between all switches in a Spanning Tree instance to maintain STP consistency. BPDU Guard is used to protect the Spanning Tree topology of a network by enforcing STP domain borders. If a port with BPDU Guard enabled on it receives a BPDU, the port will transition to a disabled state. It is recommended that BPDU Guard be applied to all access ports or client-facing ports that are not intended to be connected to a neighboring switch.
In general, in all the projects I've followed over the years, I've never seen anyone use BPDU guard on AP ports. But it's up to each individual what they want to configure on their network. 🙂
