Directing Syslog from my Meraki Cloud server to my organization
Moraks
Hello, I currently assume a role that requires i manage cloud wireless controller (Meraki) for my organization, I am struggling with sending logs from the cloud server to my LAN as required by the Audit exception, does anyone knows how to do this? I could not see syslog, but i saw 1. Change log and 2. Login attempts. is there a way I can pipe these to my internal network?
The syslogtraffic is send from the devices not from the cloud. In case of mr from the mr management ip
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Syslog_Server_Overv...
If you want to pull event from dashboard then you can use api  https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Meraki_Device_Repor...
2 Replies 2
Moraks
Thank you.
