Phillip,
Tell me if you agree with me:
- in the current scenario, running a wireshark, I can capture from the same workstation I use for testing, in this case authenticating on the cisco aironet network, it receives the hostname as user as a parameter. So I think that this config you informed is already applied, right? Image below:
At Meraki, on the same workstation, authentication only arrives with the username:
