Automated password for Guest wireless user
Josh_14
Hi all, Has anyone implemented or know a way to automate a password on weekly basis for a Meraki guest user account?
Accepted Solutions
BrechtSchamp
Re: Automated password for Guest wireless user
You could also use the dashboard API to change the password weekly with a timed script.
PUT Update the attributes of an SSID
HTTP REQUEST
PUT /networks/[networkId]/ssids/[number]
PARAMETERS
Parameter Description
nameThe name of an SSID
enabledWhether or not an SSID is enabled
authModeThe association control method for the SSID ('open', 'psk', 'open-with-radius', '8021x-meraki' or '8021x-radius')
encryptionModeThe psk encryption mode for the SSID ('wpa', 'wep' or 'wpa-eap')
pskThe passkey for the SSID. This param is only valid if the authMode is 'psk'
wpaEncryptionModeThe types of WPA encryption. ('WPA1 and WPA2' or 'WPA2 only')
splashPageThe type of splash page for the SSID ('None', 'Click-through splash page', 'Billing', 'Password-protected with Meraki RADIUS', 'Password-protected with custom RADIUS', 'Password-protected with Active Directory', 'Password-protected with LDAP', 'SMS authentication', 'Systems Manager Sentry', 'Facebook Wi-Fi', 'Google OAuth' or 'Sponsored guest'). This attribute is not supported for template children.
radiusServersThe RADIUS 802.1x servers to be used for authentication. This param is only valid if the authMode is 'open-with-radius' or '8021x-radius'
hostIP address of your RADIUS server
portUDP port the RADIUS server listens on for Access-requests
secretRADIUS client shared secret
radiusCoaEnabledIf true, Meraki devices will act as a RADIUS Dynamic Authorization Server and will respond to RADIUS Change-of-Authorization and Disconnect messages sent by the RADIUS server.
radiusFailoverPolicyThis policy determines how authentication requests should be handled in the event that all of the configured RADIUS servers are unreachable ('Deny access' or 'Allow access')
radiusLoadBalancingPolicyThis policy determines which RADIUS server will be contacted first in an authentication attempt and the ordering of any necessary retry attempts ('Strict priority order' or 'Round robin')
radiusAccountingEnabledWhether or not RADIUS accounting is enabled. This param is only valid if the authMode is 'open-with-radius' or '8021x-radius'
radiusAccountingServersThe RADIUS accounting 802.1x servers to be used for authentication. This param is only valid if the authMode is 'open-with-radius' or '8021x-radius' and radiusAccountingEnabled is 'true'
hostIP address to which the APs will send RADIUS accounting messages
portPort on the RADIUS server that is listening for accounting messages
secretShared key used to authenticate messages between the APs and RADIUS server
ipAssignmentModeThe client IP assignment mode ('NAT mode', 'Bridge mode', 'Layer 3 roaming', 'Layer 3 roaming with a concentrator' or 'VPN')
useVlanTaggingDirect trafic to use specific VLANs. This param is only valid with 'Bridge mode' and 'Layer 3 roaming'
concentratorNetworkIdThe concentrator to use for 'Layer 3 roaming with a concentrator' or 'VPN'.
vlanIdThe VLAN ID used for VLAN tagging. This param is only valid with 'Layer 3 roaming with a concentrator' and 'VPN'
defaultVlanIdThe default VLAN ID used for 'all other APs'. This param is only valid with 'Bridge mode' and 'Layer 3 roaming'
apTagsAndVlanIdsThe list of tags and VLAN IDs used for VLAN tagging. This param is only valid with 'Bridge mode', 'Layer 3 roaming'
tagsComma-separated list of AP tags
vlanIdNumerical identifier that is assigned to the VLAN
walledGardenEnabledAllow access to a configurable list of IP ranges, which users may access prior to sign-on.
walledGardenRangesSpecify your walled garden by entering space-separated addresses, ranges using CIDR notation, domain names, and domain wildcards (e.g. 192.168.1.1/24 192.168.37.10/32 www.yahoo.com *.google.com). Meraki's splash page is automatically included in your walled garden.
minBitrateThe minimum bitrate in Mbps. ('1', '2', '5.5', '6', '9', '11', '12', '18', '24', '36', '48' or '54')
bandSelectionThe client-serving radio frequencies. ('Dual band operation', '5 GHz band only' or 'Dual band operation with Band Steering')
perClientBandwidthLimitUpThe upload bandwidth limit in Kbps. (0 represents no limit.)
perClientBandwidthLimitDownThe download bandwidth limit in Kbps. (0 represents no limit.)
HEADERS
X-Cisco-Meraki-API-Key
{{X-Cisco-Meraki-API-Key}}
Content-Type
application/json
BODY
    "name": "viaPostman935",
    "enabled": false,
    "splashPage": "None",
    "perClientBandwidthLimitUp": 0,
    "perClientBandwidthLimitDown": 0,
    "ssidAdminAccessible": false,
    "ipAssignmentMode": "NAT mode",
    "authMode": "open"
Here are the docs for that endpoint:
https://documenter.getpostman.com/view/897512/meraki-dashboard-api/2To9xm?version=latest#712cd25d-f8...
50 REPLIES 50
Splash Access do a rotating WPA2-PSK option with a QR code for configuring guest WiFi devices.
https://www.splashaccess.com/
BrechtSchamp
HTTP REQUEST
PARAMETERS
HEADERS
Content-Type
application/json
BODY
    "enabled": false,
    "authMode": "open"
Josh_14
Thanks for the info. Appreciate it
BrechtSchamp
You're welcome.
nealgs
a bit late to the camp but I recently just finished a powershell script and implemented it last week:
It generates a random password (length and complexity can be changed in the script), it then updates the relevant SSID in the required site and emails the password to the reception mailbox.
Site name and SSID name are passed as parameters to the script.  Its currently used for just the guest wifi, but can obviously be used for any that uses a PSK.
It's scheduled to run at 4pm Fridays (this gives reception time to print out the new password ready for the nights and weekend security teams.
e.g.:
MerakiPSKTool.ps1 -site <sitename> -ssid <ssidname>
rgds
Gary
DillonofAnch17
great question!
Ven
This is exactly what I'm looking for.  SSID's psk must be changed once a month and the password emailed to a distro list.
Can you share your script?  I'm no good with power shell, but some folks here are.  I'm sure I could get them to help me implement.
thanks!
CMDRTucker
Gary,
   Is your script available to share?  I am looking for something like this as well.  I am trying Splash Access now but I only want just that feature from them and not the whole package.  I don't think they price it separately.  There's automates the rotating of the PSK, but I believe I can only do one SSID.
Thanks,
   Steve
BrechtSchamp
For those still looking to do this. I just wrote a script to do it. You can find it here:
https://community.meraki.com/t5/Wireless-LAN/Automatic-rotating-PSK-for-wireless/m-p/66028/highlight...
nealgs
Hi Steve,
Below is the powershell script - As it stands, it is hard coded for a single organisation as the base URI contains the Org ID
You will just need to populate the necessary areas with your particular details etc.
I.E. smpt server and recipient info in function sendMail
API key in function Get-WifiSSID
base_uri & api_key in #setup some global static stuff section
email message body in section # build email message body and send it
You can change password length (currently 10 chars) and complexity by changing the code in function createPassword
 param([string]$site="",[string]$ssid="",[string]$action="")
 function sendMail([string]$txtbody)
     #SMTP server name
     $smtpServer = "<InsertYourSMTPMailServerInfoHere>"
     #Creating a Mail object
     $msg = new-object Net.Mail.MailMessage
     #Creating SMTP server object
     $smtp = new-object Net.Mail.SmtpClient($smtpServer)
     #Email structure
     $msg.From = "merakiapi@<YourMailDomainHere>"
     $msg.To.Add("<RecipientMailAddressHere>")
	 #$msg.To.Add("<OtherRecipientAddressHere")
     $msg.subject = "New password for guest Wifi"
     $msg.body = $txtbody
	 $msg.IsBodyHTML=$true
     #Sending email
     $smtp.Send($msg)
function Get-RandomCharacters($length, $characters)
    $random = 1..$length | ForEach-Object { Get-Random -Maximum $characters.length }
    $private:ofs=""
    return [String]$characters[$random]
function Scramble-String([string]$inputString)
    $characterArray = $inputString.ToCharArray()
    $scrambledStringArray = $characterArray | Get-Random -Count $characterArray.Length
    $outputString = -join $scrambledStringArray
    return $outputString
function updateWiFiPSK ([string]$s_id, [string]$w_id, [string]$newpassword)
	[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
	# PSK = New password
	$data = @{
		"psk" = $newpassword
	#Convert data to Json format
	$jbody = ConvertTo-Json -InputObject $data
	#Combine base URL and ssid
	$request_uri = $base_uri + $networks_uri + $s_id + "/ssids/" + $w_id
	$r = Invoke-WebRequest $request_uri -Method:Put -Headers $header_org -Body $jbody
	return $r
function Get-SiteID
    #get site id
    $r = Invoke-WebRequest $request_uri -Method:Get -Headers $header_org
    $json = $r | ConvertFrom-Json
    for($i=0;$i -lt $json.count;$i++)
        if ($site -eq $json[$i].name)
            Write-host "Network Name : " $json[$i].name
            Write-host "id           : " $json[$i].id
            Write-host "Type         : " $json[$i].type
            $s_id = $json[$i].id
    return $s_id
function Get-WiFiSSID ([string]$s_id)
    #get wifi network ID from site requested
    if ($s_id -ne "")
        $r = Invoke-WebRequest $request_uri -Method:Get -Headers @{"X-Cisco-Meraki-API-Key"="<ReplaceWithYouAPIKeyHere>"} -ContentType "application/json"
        $z = $r | ConvertFrom-Json
        for($i=0;$i -lt $z.count;$i++)
            If ($z[$i].name -eq $ssid)
                Write-host "SSID Name    : " $z[$i].name
                Write-host "SSID#        : " $z[$i].number
                Write-host "Current PSK  : " $z[$i].psk
                $w_id = $z[$i].number
    return $w_id
	$password = Get-RandomCharacters -length 4 -characters 'abcdefghiklmnoprstuvwxyz'
	$password += Get-RandomCharacters -length 2 -characters 'ABCDEFGHKLMNOPRSTUVWXYZ'
	$password += Get-RandomCharacters -length 2 -characters '1234567890'
	$password += Get-RandomCharacters -length 2 -characters '!$%&()?}][{@#+'
	#Write-Host $password
	return Scramble-String $password
# setup some global static stuff
$base_uri = "https://<InsertYourMerakiAPIBaseURLHere>"
##    E.G.   n34.meraki.com/api/v0/organizations/<OrgID>/
$networks_uri = "networks/"
#Meraki API KEY
$api_key = "<InsertYourAPIKeyHere>"
$header_org = @{"X-Cisco-Meraki-API-KEY" = $api_key;"Content-Type" = 'application/json'}
$s_id = ""
$w_id = ""
$mode = ""
If ($site -eq "" -or $ssid -eq "")
    Write-Host "MerakiPSKTool - (c) 2019"
    Write-Host ""
    Write-Host "Site/SSID parameter is missing"
    Write-Host "Usage: MerakiPSKTool.ps1 -site <sitename> -ssid <ssidName> -action [Change | Display]"
    Write-Host ""
    exit
# if action not passed or is blank, set default mode to Display
if ($action -eq "")
    $action = "Display"
switch ($action)
    {@("Display", "display") -contains $_ }
            "Displaying Wifi details"
            $mode = "display"
    {@("Change", "change") -contains $_ }
            "Change Wifi password"
            $mode = "change"
    default { "MerakiPSKTool.ps1" }
# get ID of the site passed in params (set a default value if no site passed)
$s_id = Get-SiteID
If ($s_id -ne "")
    # get id of Wifi network that password is to be changed for
    $w_id = Get-WifiSSID($s_id)
    #Write-Host "Site ID      : " $s_id " | Wifi #: " $w_id
if ($mode -eq "change")
    # generate a new complex password
    $newpassword = createPassword
    $result = updateWiFiPSK $s_id $w_id $newpassword
    #Write-Host $result
    if ($result.StatusCode -eq 200)
        Write-Host "Sending Email"
        $txtbody = "<html><body>"
        $txtbody = $txtbody + "The new password for " + $ssid + " at " + $site + " is<br><br><b><font size=30 color=green>"
        $txtbody = $txtbody + $newpassword + "</font></b>"
        $txtbody = $txtbody + "<br><br>If you have any problems please contact <SomeContactDetailsHere>"
        $txtbody = $txtbody + "<br><br>regards<br>SignoffInfo"
        $txtbody = $txtbody + "</body></html>"
        #Write-Host $txtbody
		# send the email
        sendMail $txtbody
    else
        Write-Host "Password change failed for " + $ssid + " at " + $site
Copy and paste the above into text editor, make the necessary changes and save as MerakiPSKTool.ps1
to display current PSK for site, use
MerakiPSKTool.ps1 -site <sitename> -ssid <SSIDName> -action Display
to change psk for site use
MerakiPSKTool.ps1 -site <sitename> -ssid <SSIDName> -action Change
if no Action value provided it will default to Display
Current email body looks like this:
The new password for [ssidName] at [SiteName] is
z$ys$63mPX
If you have any problems please contact [ContactName] on [ContactTel] or [ContactEmail]
regards
[Contact]
Subject line is New password for guest Wifi
I'm not a pro programmer so use at own risk, i've had it running now for a good couple or months or so now and it's worked fine since.
rgds
Gary
CMDRTucker
nealgs,
  THANK YOU for the reply.  I am getting an error that I think may be related to the base URL.  I am not sure where I find the orgid?  Can you give me a pointer on that please?
Thanks,
   Steve
nealgs
hi Steve,
from your Meraki dashboard, type this url into address bar
https://dashboard.meraki.com/api/v0/organizations
or even just append your dashboard address to be
https://<yourdashboardurl>/api/v0/organizations
and press Enter - it should then return some json info:
[{"id":"<yourOrgID>".......
use the value in there for orgid - think it's a 6 digit number, at least ours is
Ven
Thanks BrechtSchamp!
I've just gotten started with Python, so this is a great script to use and learn!
I'm working on one that will run multiple remote commands on multiple Cisco wireless controllers. So far, it's very promising.
STM
I have got following error message when I try with "Change" option. "Display" option is okay. Can help me check this error?
Invoke-WebRequest : The remote server returned an error: (400) Bad Request.
At C:\Users\sithu\Dropbox\AMNET\Meraki WiFi PSK Auto Generate\MerakiPSKTool.ps1:56 char:7
+ $r = Invoke-WebRequest $request_uri -Method:Put -Headers $header_ ...
+ CategoryInfo : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebException
+ FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
nealgs
Hi STM,
Can you confirm you have made all of the necessary changes in the script to contain your meraki details
i.e the values for $request_uri, $header_org and $jbody etc have been set correctly
Gary
STM
Hi Nealgs,
Yes, I made necessary changes in script. I can see the SSID PSK with "Display" switch. But I cannot change the PSK. If I run with "Change" switch, this error occurs.
Following is my Script that I add required parameters.
     #SMTP server name
     $smtpServer = "xxx.xxx.xxx.xxx"
     #Email structure
     $msg.From = "merakiapi@xxx.com"
     $msg.To.Add("xxx@xxx.com")
     #Sending email
     $smtp.Send($msg)
    $private:ofs=""
function updateWiFiPSK ([string]$s_id, [string]$w_id, [String]$newpassword)
$data = @{
        "encryptionMode" = "wpa"
        "authMode" = "psk"
return $r
function Get-SiteID
    #get site id
    return $s_id
    if ($s_id -ne "")
        $r = Invoke-WebRequest $request_uri -Method:Get -Headers @{"X-Cisco-Meraki-API-Key"="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"} -ContentType "application/json"
    return $w_id
#Meraki API KEY
$api_key = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
$s_id = ""
$w_id = ""
$mode = ""
    Write-Host ""
    Write-Host ""
    exit
if ($action -eq "")
    $action = "Display"
switch ($action)
            $mode = "display"
            $mode = "change"
$s_id = Get-SiteID
If ($s_id -ne "")
    #Write-Host $result
        $txtbody = $txtbody + "<br><br>If you have any problems please contact XXX"
# send the email
        sendMail $txtbody
    else
Thanks a lot for your reply.
Regards,
nealgs
I've never tried the code changing or adding anything more than just the password value.
Can you try it but remove the entries in the $data section so it looks like this:
$data = @{
I'd suggest installing Postman app and getting the Meraki API collection - it allows you to mess around with calls etc and see the results.
regards
Gary
nealgs
for multiple values in $data i think they need to be separated by commas
$data = @{
        "encryptionMode" = "wpa",
        "authMode" = "psk",
STM
Hi nealgs,
If I add comma and run the script, it got following issue.
At C:\Users\sithu\Desktop\MerakiPSKTool.ps1:47 char:28
+ "encryptionMode" = "wpa",
The assignment expression is not valid. The input to an assignment operator must be an object that is able to accept assignments, such as a variable or a property.
At C:\Users\sithu\Desktop\MerakiPSKTool.ps1:48 char:9
+ "authMode" = "psk",
At C:\Users\sithu\Desktop\MerakiPSKTool.ps1:48 char:22
At C:\Users\sithu\Desktop\MerakiPSKTool.ps1:49 char:3
+ "psk" = $newpassword
+ CategoryInfo : ParserError: (:) [], ParseException
+ FullyQualifiedErrorId : InvalidLeftHandSide
If I don't add this two parameters "encryptionMode=wpa, authMode=psk", I got following issue when I run the script with "change" switch.
At C:\Users\sithu\Desktop\MerakiPSKTool.ps1:56 char:7
Thank you.
nealgs
Hi STM,
Ok, i've just tried the script out changing multiple values
$data = @{
    "authMode" = "psk"
    "psk" = $newpassword"
I tried with commas and it generated the errors - remove commas and it runs and changes the password ok.
Not sure why you want to include/change authmode and encryptionmode as i'd thought they would stay the same each time?
Gary
STM
Hi nealgs,
I also tried and get the new PSK from email. But when I check the SSID PSK on Meraki dashboard, it display old PSK.
It should display the updated PSK, right?
Regards,
nealgs
Add the following line in green (code is around line 184) into the script - this will display the new password as well
Write-Host "New Password : " $newpassword
    #Write-Host $result
it'll can take a couple of mins for the Meraki portal to show the changed password - but if you run the script again in display mode, it should show the new password as the Current password.
run script in display mode gets this output:
Network Name : <nameofnetwork>
Type : combined
SSID Name : APITest
SSID# : 5
Current PSK : TkGl55[&51
run in change mode should show the output below after you put in the extra line in the script:
Type : combined
SSID Name : APITest
SSID# : 5
New Password : 8$1vA9p4T[
Sending Email
Paste your results in here once run
Gary
STM
Hi nealgs,
This is output of "change".
Network Name : STM-HQ
Type : wireless
SSID Name : GUEST_WIFI
SSID# : 1
Current PSK : 73gbL#!Bym
New PSK : pWD%3hc4a$
Sending Email
This is output of "display". It shows updated password.
Type : wireless
SSID# : 1
Current PSK : pWD%3hc4a$
For SSID PSK in Meraki dashboard, it still shows very old one.
But we don't need to take note that PSK right?
nealgs
looking at the output, the psk is being changed correctly
the display mode lists the current psk password it get it's from the ssid you provide so it is reading correct one and looks to be working ok.
I don't quite understand your line:
for the display mode to show the correct value, then the value in the Meraki Dashboard must also be correct as they both read the value from the same location (i assume).
Gary
JoshMikow
Once the SSID password is changed, is there an easy way to tell it to sync across to other networks?
nealgs
Hi JoshMikow,
As the code stands, no - it's per SSID in a named Network.  You'd have to run it once for each SSID in each network.  It would require a fair bit of change to do what you want.
I do have plans in the near future to amend it so that you can change the password for a named SSID across all networks - this is because we have a corporate wifi that we want to be able to sync passwords with to allow cross site visitors to be able to automatically access the Corporate Wifi once onsite - just waiting for the relevant infrastructure to be installed and setup to allow this (e.g. MR devices at those sites without)
I don't think there is a Meraki API call or anything in the Meraki Dashboard that will do what you need either.
rgds
Gary
JoshMikow
Thanks Gary. I'm also looking into using Configuration Templates to see if that would be a way to sync the settings. New to the API so I'm trying to make it as simple but secure as possible.
DavisJ
Thank you for the awesome script. I am just trying to run the script in display mode and all I see is 'Displaying Wifi details' but nothing after that, any ideas?
Thanks,
Davis
nealgs
Hi Davis,
Make sure you have the correct specific info in place - e.g. network id, API key etc
rgds
Gary
DavisJ
Hi Gary,
Thank you for your quick response - where in your code should I include the network ID? Sorry, I tried to find it but I couldn't.
I have updated the API key.
Thanks,
Davis
nealgs
Hi Davis,
In the original posting the changes you need to make are
If you search for the text bolded above, that will take you to the relevant areas you need to modify with your info
in the code
give me a shout if any more help needed 🙂
DavisJ
Yes, I have done those (above mentioned) changes already except for updating the 'network ID' and I couldn't tell where to include this info. What am I missing?
Thank you,
Davis
DavisJ
My bad, I was missing the '/' at the end of $base_uri and I can get the output finally using the 'Display'.
I will try to use the 'Change' as well as do further testing and get back if I need any help.
Thank you for your assistance, much appreciated.
nealgs
Good to hear you got it sorted 🙂
No problem - drop a post in here if any more issues.
Taslim
HI Nealgs
I am not getting clear about update Get-WifiSSID value in script, please help on this
Taslim
Getting Below error, Please help.
+ CategoryInfo : ObjectNotFound: (MerakiPSKTool.ps1:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
nealgs
Hi Taslim
Can you provide a screenshot of how you are attempting to run the script - the error seems to be incomplete as it's not saying which Command isn't found.
I've not seen that error during my testing and final implementation of the script.
rgds
Gary
nealgs
Hi Taslim,
You need to apply for an API access code the value of which goes into the Get-WifiSSID function
Go to Organisation/Settings and scroll down to bottom.  You should see a section called
Dashboard API Access
tick Enable access too ..... and following instructions to get you API key
This key then goes into the code sections Get-WifiSSID function and the setup some globals section
rgds
Gary
Taslim
Hi Neagls,
First of all thanks to your all help.
I have set the API key and i am able to communicate the API, i tested through https://developer.cisco.com/meraki/api-v1/#!update-network-wireless-ssid.
nealgs
Hi Taslim,
The first error message (red text on blue) usually occurs if you don't provide the full path to a Ps1 script.
So for example, my merakipsktool.ps1 file resides in
C:\tst\powershell
if i'm in Powershell ISE, then i'd CD to c:\tst\powershell
and to run the script, i'd type
.\merakipsktool.ps1
this displays the the copyright sign and a message that the site/ssid parameter was missed
The 2nd screen where yours appears to show nothing i'd say is due to something not being entered correctly in the areas of the script that need to be changed to have your Meraki specific details.
Can you double check them again, and make sure you include a '/' at the end of $base_uri variable - (see DavisJ post earlier)
rgds
Gary
Taslim
Hi Nealgs,
Yaa i was missing / at the end of Base Uri, Now Display action working perfectly, however change action not working getting below error.
PS C:\Users\test\desktop> .\merakipsktool.ps1
Network Name :  Name of network
Type         :  wireless
SSID Name    :  SSID Name
SSID#        :  0
Current PSK  :  Nn!v5Gz)DHkvp=
At C:\Users\test\desktop\MerakiPSKTool.ps1:55 char:7
+     $r = Invoke-WebRequest $request_uri -Method:Put -Headers $header_org -Body $jbo ...
   eption
Password change failed for  + SSID Name +  at  + Name of Network
Taslim
param([string]$site=" changed according to us ",[string]$ssid="changed according to us",[string]$action="Display")
     #SMTP server name
     $smtpServer = " changed according to us "
     #Email structure
     $msg.From = "merakiapi@ changed according to us "
     $msg.To.Add("changed according to us ")
     #Sending email
     $smtp.Send($msg)
    $private:ofs=""
              $data = @{
              return $r
function Get-SiteID
    #get site id
    return $s_id
    if ($s_id -ne "")
        $r = Invoke-WebRequest $request_uri -Method:Get -Headers @{"X-Cisco-Meraki-API-Key"=" changed according to us "} -ContentType "application/json"
    return $w_id
$base_uri = "https://nXX.meraki.com/api/v0/organizations/ changed according to us/ "
#Meraki API KEY
$api_key = " changed according to us "
$s_id = ""
$w_id = ""
$mode = ""
    Write-Host ""
    Write-Host "Usage: MerakiPSKTool.ps1 -site changed according to us -ssid changed according to us -action [Change | Display]"
    Write-Host ""
    exit
if ($action -eq "")
    $action = "Display"
switch ($action)
            $mode = "display"
            $mode = "change"
$s_id = Get-SiteID
If ($s_id -ne "")
    #Write-Host $result
                             # send the email
        sendMail $txtbody
    else
Taslim
Hi Gary,
Change Output
Network Name :  XXXXXX
Type         :  wireless
SSID Name    :  XXXXX
SSID#        :  1
Current PSK  :  k7fB37!oER#t$N
New Password :  W$)c7uss4W
At C:\Users\Test\Desktop\MerakiPSKTool.ps1:55 char:7
   t], WebException
   mmand
Password change failed for  + XXXXX +  at  + XXXXXX
Display output
Network Name :  XXXX
Type         :  wireless
SSID Name    :  XXXX
SSID#        :  1
Taslim
All good now its working as expected.
Thanks lots
Taslim
Hi Gary,
Is there any script available to change the PSK if site network managed by configuration template, i tried with couple of change but not working.
nealgs
Hi Taslim,
Good to hear 🙂
What was the problem in the end - would be good to know in case someone else has similar issues.
rgds
Gary
nealgs
Hi Taslim
Sorry can't help on that one im afraid - not really used config templates, so not sure how they differ with regards to directly changing a SSID psk.
rgds
Gary
Jason7
Great script, thanks.
Using the script as is I got the below error due to TLS issues.
The underlying connection was closed: An unexpected error occurred on a send.
Adding the below line before invoking the web request did the trick.
nealgs
Hi Jason7,
I've never seen that error before 🙂 very strange.  I've had the script running for over a year now.  Executes a scheduled task at 4pm every Friday to change the guest wifi password and sends out and email to a couple of recipients with the new one.
The line you entered already exists in the function updateWiFiPSK
rgds
Gary
